NSG: Network Signal Guru. Il Netmonitor Android Definitivo.
L'ultima versione mi provoca un reboot del telefono, sono tornato alla precedente. Ho uno Snapdragon 410.
Io ho uno xiaomi redmi note pro 3 special edition (Snapdragon 650) qualcuno percaso ha testato questa applicazione su questo telefono?
DeeDeND ha detto:
in teoria dovrebbe andare
DeeDeND ha detto:
Facci sapere, questo telefono è molto intrigante..... ed ha anche la banda 20
NSG supports XIAOMI devices(qualcomm chipset) very well. many newest devices are running NSG, including Xiaomi NOTE2, XIAOMI MIX, Mi 5S&PLUS(announced this month).
aside from that, all of xiaomi devices are providing official channel to root. it's the best way to use NSG.
Kijuz ha detto:
Hi qtrun.
Some questions:
1. Is there a way to read the log files without licensed sw such as qcat or qxdm?
2. Is there a way to replay logs on nemo outdoor?
3.Is there a free sw to replay the log?
4.Can you implement the replay of a specific log file saved in NGS?it would be perfect.
5.Is there a possibility to view all the information without record a log file, and record a specific log only when the user wants? Ngs produce many log files that periodically the user must delete.
Thanks in advance for your time
Hi qtrun, i re-send you some questions from my previous post . i'm curious :) . is there some possibility ? Sorry for my questions
Kijuz
Kijuz ha detto:
Kijuz
there's no such free sw to replay, view and analyze NSG log files. it's quite professional and complicated. so there's no way so far as I know. NSG will provide a way to replay but you have to wait. NSG save 5 logs for debug purpose and will be deleted when the file is out of date. We are using actix analyzer, QCAT and TEMS to read these files.
qtrun ha detto:
Would be perfect if we could export a log to CSV or XLS format from within NSG..
qtrun ha detto:
Many thanks! I'll wait for the replay feature.
qtrun ha detto:
Hi qtrun, my colegue has actix analyzer but we can't open the log files produced by nsg. How can i open it? Is there a procedure to open the log files?
Many thanks
Ho provato a installarlo, allego un paio di screenshot
Sent from my Redmi Note 3 using Tapatalk
Non è la versione completa.
Hai fatto il root?
No non ho ancora fatto il root... Appena ho un po' di tempo/voglia mi ci metto :p
DeeDeND ha detto:
Bene, perché così non serve a molto
Hi Qtrun.
I tried to open the NSG program and why i am advised the program expires. That limit has been set? You can not use an app "old" infinitely?.
I was forced to upgrade the program, as i was never required an internet connection? Something is sent from my phone?.
Thank you.
Regards.
Hi Qtrun.
Thank you.
Regards.
Serve internet al primo accesso per scaricare la configurazione adatta al tuo telefono.
Credevo rimanesse impostata dalla vecchia app, è fenomenale niente da dire. Con il sammy e blocco bande, testo di tutto e ormai i weekend volano con le reti :D.
Appena ottengo il root sul mio Redmi note 3 provo a vedere anch'io come va questo programma, però dovrò leggermi qualche guida su come funziona il 4G perché io ero rimasto al 2G 😬
Sent from my Redmi Note 3 Pro Special Edition "kate"
