NSG: Network Signal Guru. Il Netmonitor Android Definitivo.
Ghostrider ha detto:
Nell'ultima versione scaricata dal play store mi esce solo una pagina di analisi. Sono quindi tornato alla versione precedente. Mi viene un dubbio: avrei dovuto per caso riavviare il cellulare per completare la corretta installazione?
Probabilmente non ha preso il root. Basta togliere e ridare i consensi. Sarebbe meglio prima anche disinstallare la vecchia.
1800+ stands for the band definition by 3GPP. it's from http://niviuk.free.fr/lte_band.php,
besides, MIMO 2x2, 4x2, 1x1 is presenting the MIMO configuraitons of NodeB. 2x2 means 2 tx antenna and 2 rx antenna, MIMO configured. 1x1, 1 tx and 1 rx, no mimo(SISO, single input single output)
The app doesn't work correctly on the Nexus 5x running Android N. Once you try to lock to one rat or you band lock if you try "clear all" you loose connection for good. Even in android settings you get "unknown" and there's no fix unless you reboot.
actually we haven't tested nsg on andoird 7.0 because we cannot find a device. please understand. nexus phone is not sold in our country...
qtrun ha detto:
It's not big deal, I just need to avoid using "clear all" otherwise it's working just fine
Ma anche Huawei con processore Kirin supporta? Incredibilmente Huawei a partire da Lollipop non mostra più la banda nel service menu. :(
luchella ha detto:
No, solo chipset Qualcomm.
Hisilicon is not as good for testing as Qualcomm. some guys in China tested it. when it is turned into a test phone, the mainboard will crash and the phone cannot be used any more. that's why we don't have the plan to put the resource on Huawei chipset phones.
May we hope that someday Exynos processors will be supported? :p
we hope but we cannot do it currently because Samsung baseband is not allowed into market in our country and neither in USA, Japan and India because Shannon modem is not a good option for complicated networking.
In europe it can be possible because european networks are very simple.
hhc
@qtrun ,
I have a technical curiosity, to get all the values of the cells via AT Command read or by vendor/Ril ??
Tks
hhc ha detto:
@qtrun ,
Tks
at command and RIL both are nearly the same and they can achieve some data at a very low rate and speed.
android are using RIL to get cell data. cell mapper and other tools are using android interface to get data. it's not powerful but a low cost option
scusate se è già stato trattato, ma come mai su S4 in modalità advanced appare "Halted" e nessun valore?
:surrender:
Marcus91 ha detto:
:surrender:
please upgrade your android to 6.0(CM13) or downgrade to 4.x, in version 5.0, Samsung removed the drivers that NSG need. I think CM 13 will be a better option for you...
