NSG: Network Signal Guru. Il Netmonitor Android Definitivo.
MotoE2 is ok for advanced mode... I can see some canadian guys are using it... you don't have root access. do it first and retry...
qtrun ha detto:
Hi qtrun, have you ever had any feedback about your software installed on a z5 compact?
Can you make it rooted?if you can, just do it... you lose nothing...
I have checked the database, most rooted sony devices are OK in Advanced Mode...
qtrun ha detto:
Ok thank you! I will try to make it and give you a feedback
I'm having problems with band locking on my Nexus 5X. For instance when I want to lock at one specific LTE band if the signal is not present on that band even if if the RAT is on LTE it will automatically go back to 3G or 2G. Basically it ignores the RAT locking. Is this how some Qualcomm chipsets work?
Also it would be great if you could add "select/unselect all" for bands in the l band ocking screen since on my Nexus 5X I have 20 supported bands only on LTE and it's a bit tricky to isolate one specific band.
Right now, Nexus 5 is not ok for advanced mode, we don't know what google has done to the rom... fortunately some guys in China changed the rom to Xiaomi(4.4) and they can get the advanced mode... we can see that...
if you can, maybe that's the way...
Nexus 5X and Nexus 6 is ok, but Nexus 6P is partly OK(No band locking, No forcing features)
This is a message from Nexus 5 users...
"I put Cyanogenmod 13 on my Nexus 5 and opened network signal guru on it and it worked great. Band lock and RAT locking work as well. Much appreciated in this tip. "
Is there any Nexus 6P users or HTC users, download the CM ROM... and have a try...
qtrun ha detto:
Thanks!
Qtrun si possibile to next version block sigle pci or psc? Thanks
Nuova versione 0.9
Novità
New:
1. Map Improvements;
2. LTE CA Matrix;
3. VoLTE supports;
4. Graph Syncs;
5. TD-SCDMA decodings;
6. Scroll Supports to small size screens;
7. Battery Preferences settings.
Fix:
1. LTE MIMO antennas;
2. LTE RRC Decoding Crashes;
3. Wireless Attributes sampling by time(C/I, SINR, etc);
4. CDMA channel list errors;
5. Errors in LTE uplink attributes;
6. Display error in low density screens.
veramente ottimo :D spero consumi meno ora ... spero aggiungano la possibilità di bloccare i psc - pci
