NSG: Network Signal Guru. Il Netmonitor Android Definitivo.
Mmmm che strano....
Credo di averle provate tutte, ma niente.
Nessun altro ha problemi?
In Italian and English:
ho installato la app due giorni fa ma non mi funziona la mappa, come mai? Ho un Elephone Trunk rootato con android 5.1
I installed this app a couple of days ago and quite strangely the map doesn't work at all. Any idea? My cellphone is a Elephone Trunk, root and android 5.1
Thanks
qtrun ha detto:
band locking is not safe. we must be very careful before we release this feature.
if any problems happened to your phone by band locking, your cell phone cannot be used without any professional help...
right now just check the band class capabilities within your phone. we will do more test before this feature is released
please understand...
BR
Yup, it happened a couple of days ago. I did not know that locking the band was too risky and I discovered with utter disbelief that my other bands were gone! It just worked in LTE but since VOLTE is not supported yet, I could not receive and do calls anymore (no fallback). I was shocked. At the beginning I thought about a recovery restore, then on guy on an Italian forum told me to move the selector to "auto". Even so, my bands were not working properly, so I launched manual research and forced the network to register on my carrier. This solved the problem. I was seriously worried cause my phone is for work and free time, and I love it :)
Ghostrider ha detto:
Va be dai lo sanno anche i muri che in 4G se il tuo gestore non supporta il volte le chiamate non vanno :p
You're confusing "technology" locking with band locking.
gentleman, would you please post your picture of "show band"(LTE GSM WCDMA) here so we can see the band capabilities? thank you very much...
Example in my telephone (S4 mini), in the network Wind (2G/3G/4G).
Ciao a tutti,
Come avrete notato la discussione si è persa praticamente del tutto per un problema dovuto allo spostamento di alcuni post. Essendo una rimozione fisica, per ripristinare i messaggi sarebbero andati persi diversi post da altre discussioni pertanto si è deciso di non procedere visto che in questa discussione non erano presenti informazioni fondamentali, dunque proseguite pure a parlare di questa fantastica app e ci scusiamo per il disagio.
Grazie a tutti.
Pazienza, c'era qualche screenshot ma niente di che. A questo punto meglio lasciare così che procedere al recupero e magari sorgono altri problemi. Sbagliando si impara:p.
qtrun ha detto:
Hi qtrun. This is my lg g4.
If I select only b3 under Supported Bands for LTE, my phone should only connect to that band? I thought that band locking hadn't been implemented yet.
gianfranco ha detto:
No. Al momento il blocco banda non è implementato. Da quel menu si vede solo quali bande supporta il telefono.
Questa mattina all'accensione l'applicazione si è aggiornata in automatico. La versione ora è la 0.7.1 e funziona perfettamente.
Nella descrizione è proprio citato:
hotfix v0.7.0: the app stuck in "check device compatible" on some devices; or title show "Halted". (maybe need manual reboot your device)
Si confermo. Pure a me. Se qualcuno riscontrasse problemi, vi consiglio di disinstallare, togliere i permessi da SuperSu, installare nuovamente, ridare i permessi di SuperSu.
Inviato dal mio Samsung Galaxy S5 utilizzando Tapatalk
qtrun ha detto:
Here is an LG G2 D802, with AICP ROM (the exact same ROM and Android version (6.0.1) of my LG G3, in which the app crashes when I tap on Show Bands (see logcat on your email)):
ma il SINR è la stessa cosa che Cellmapper e Netmonster chiamano SNR per quanto riguarda il 4G?
perché su NSG il valore varia molte volte al secondo.....
