NSG: Network Signal Guru. Il Netmonitor Android Definitivo.
qtrun ha detto:
band locking is not safe. we must be very careful before we release this feature.
if any problems happened to your phone by band locking, your cell phone cannot be used without any professional help...
right now just check the band class capabilities within your phone. we will do more test before this feature is released
please understand...
BR
gianbyte ha detto:
L'RSCP ballerino è stato risolto?
No.
Hi qtrun the RSCP dbm value only in wcdma 2100/900 don't works correct..
precisely... right now we can only lock lower bands(GSM WCDMA LTE FDD CDMA TDSCDMA). LTE tdd band is high and it cannot be implemented...so we have to check band capabilities firstly.
as you know this app is word-widely used. in China and India, TDD is available. so we have to be 100% careful.
anyway, weekend is around the corner. enjoy your eurocup.
see you next week...
mrk2005 ha detto:
Hi, it crashes when i tap on Show Bands on my LG G3 D855 (With Cyanogenmod), Android 6.0.1. I've sent a couple of Application Error Reports (through Android), hope you got them.
That's great to hear. but we have not got your reports. make sure you are connected to internet before you report the errors. thanks...
I see, so when you lose all TDD-LTE bands it cannot be reverted back via software? Anyway I don't think TDD is used in Europe :)
qtrun ha detto:
So even if you lock just WCDMA or FDD LTE bands you lose TDD bands?
Enjoy your weekend and great job
No.
We have checked the LTE and WCDMA cell table. there's bugs when it's in mixed status. in WCDMA when FACH channel is in use, error happens. that's the same in LTE. you cannot find errors in LTE because the cell resource is much more than WCDMA. so it cover the errors. we will make it right in next release. Thanks in advance...
qtrun ha detto:
Thanks alot.
With this new version of NSG my phone sometimes is locking on this splash screen.
To start NSG i must reboot my phone.
Ciao, non ho ben capito.... c'è il blocco banda in LTE oppure no nella nuova versione?
gianfranco ha detto:
ancora non c'è il blocco banda, stanno testando il tutto.
qtrun ha detto:
Thank you too, if you solve this bug the app will be perfect on my S5 :p
qtrun ha detto:
Hi, i think it was because android tries to send the content of /data/user/0/com.qtron..../files, and there was a .jar file in there, so Gmail blocked it as a security issue. Anyway I've sent you another logcat straight to your email address, hope it helps. Thanks for you work, have a good WE.
qtrun ha detto:
Mmmmm the opposite..
In FACH is correct..
In DCH/PCH is not correct.
Su S4 mini non c'è più verso di farla funzionare :( :mad:
Su g4 ho dovuto disinstallare la vecchia. E nelle impostazioni va messo Auto al posto di Advanced. Riavvio del telefono e parte. Ci ho sbattuto un po prima di farla andare.
Niente da fare, con auto ho questo:
e con advanced questo:
Riprova con auto e fai un nuovo reboot..
Escono solo queste due schermate:
Quelle escono se setti "normal". Ma in "auto" dopo un riavvio dovrebbe andare..
È in auto dopo un riavvio...... :(
