Aggiornamenti di rete area centro "[Agg. 07/09/2015]"
PE28 set 15 08:00:00LORETO APRUTINO65014288
PE30 set 15 08:00:00LORETO APRUTINO65014288
PE30 set 15 08:00:00MANOPPELLO65024288
PE28 set 15 08:00:00MANOPPELLO65024288
PE28 set 15 08:00:00MONTESILVANO65015788
PE30 set 15 08:00:00MONTESILVANO65015788
PE28 set 15 08:00:00MOSCUFO65010888
PE30 set 15 08:00:00MOSCUFO65010888
PE28 set 15 08:00:00PENNE65017288
PE30 set 15 08:00:00PENNE65017288
PE30 set 15 08:00:00PESCARA65122188
PE30 set 15 08:00:00PESCARA65121188
PE30 set 15 08:00:00PESCARA65129488
PE28 set 15 08:00:00PESCARA65100188
PE28 set 15 08:00:00PESCARA65126288
PE30 set 15 08:00:00PESCARA65127288
PE28 set 15 08:00:00PESCARA65125188
PE28 set 15 08:00:00PESCARA65121188
PE28 set 15 08:00:00PESCARA65127288
PE30 set 15 08:00:00PESCARA65100188
PE30 set 15 00:01:00PESCARA65129181
PE28 set 15 08:00:00PESCARA65129488
PE28 set 15 08:00:00PESCARA65128288
PE30 set 15 08:00:00PESCARA65125188
PE30 set 15 08:00:00PESCARA65128288
PE30 set 15 08:00:00PESCARA65126288
PE28 set 15 08:00:00PESCARA65122188
PE30 set 15 08:00:00PIANELLA65019188
PE28 set 15 08:00:00PIANELLA65019188
PE28 set 15 08:00:00PICCIANO65010888
PE30 set 15 08:00:00PICCIANO65010888
PE28 set 15 08:00:00POPOLIND688
PE30 set 15 08:00:00POPOLIND688
PE28 set 15 08:00:00POPOLI65026188
PE30 set 15 08:00:00POPOLI65026188
PE30 set 15 08:00:00ROSCIANO65020788
PE28 set 15 08:00:00ROSCIANO65020788
PE30 set 15 08:00:00SANT'EUFEMIA A MAIELLA65020788
PE28 set 15 08:00:00SANT'EUFEMIA A MAIELLA65020788
PE28 set 15 08:00:00SCAFA65027188
PE30 set 15 08:00:00SCAFA65027188
PE30 set 15 08:00:00SERRAMONACESCA65020788
PE30 set 15 08:00:00SERRAMONACESCA65025188
PE28 set 15 08:00:00SERRAMONACESCA65025188
PE28 set 15 08:00:00SERRAMONACESCA65020788
PE28 set 15 08:00:00SPOLTORE65010888
PE30 set 15 08:00:00SPOLTORE65010888
PG30 set 15 23:00:00PERUGIA06100186
PG30 set 15 23:00:00PERUGIA06100181
PI30 set 15 08:00:00CALCINAIA56012188
PI29 set 15 08:00:00CALCINAIA56012188
PI30 set 15 08:00:00CAPANNOLI56033188
PI30 set 15 08:00:00PONTEDERA56025188
PI30 set 15 08:00:00SANTA CROCE SULL'ARNO56029188
PO30 set 15 09:00:00POGGIO A CAIANO59016186
PT30 set 15 09:00:00PISTOIA51100186
PT1 ott 15 08:00:00QUARRATA51039188
RM29 set 15 09:30:00ROMA00138183
RM1 ott 15 09:30:00ROMA00155183
RM30 set 15 22:00:00ROMA00100182
RM30 set 15 09:30:00ROMA00138183
RM29 set 15 08:00:00ROMA00155188
RM29 set 15 23:00:00ROMA00174181
RM29 set 15 23:00:00ROMA00174183
RM30 set 15 08:00:00ROMAND184
SS1 ott 15 00:01:00SASSARI07100181
TE30 set 15 08:00:00ATRI64032288
TE28 set 15 08:00:00ATRI64032288
TE30 set 15 08:00:00BISENTI64033188
TE28 set 15 08:00:00BISENTI64033188
TE28 set 15 08:00:00CAMPLI64012188
TE30 set 15 08:00:00CAMPLI64012188
TE30 set 15 08:00:00CASTEL CASTAGNA64030288
TE28 set 15 08:00:00CASTEL CASTAGNA64030288
TE30 set 15 08:00:00CASTILENTI64035188
TE28 set 15 08:00:00CASTILENTI64035188
TE28 set 15 08:00:00CELLINO ATTANASIO64036188
TE30 set 15 08:00:00CELLINO ATTANASIO64036188
TE30 set 15 08:00:00MONTEFINO64030288
TE28 set 15 08:00:00MONTEFINO64030288
TE30 set 15 08:00:00PINETO64025188
TE28 set 15 08:00:00PINETO64025188
TE30 set 15 08:00:00SILVIND688
TE30 set 15 08:00:00SILVI64028488
TE28 set 15 08:00:00SILVIND688
TE28 set 15 08:00:00SILVI64028488
TE28 set 15 08:00:00TERAMO64100288
TE30 set 15 08:00:00TERAMO64100288
VT29 set 15 08:00:00VITERBOND184
Alla faccia... ci danno dentro :D
Mi sa che ci sono stati aggiornamenti anche al sud. Da me, anche se non ha piovuto ci sono stati disservizi, il segnale spariva per poi ritornare in continuazione.
PROVINCIADATA INIZIO ATTIVITALOCALITACAPSITI IMPATTATINEW ORA INIZIONEW DURATA
NU2 ott 15 06:00:00DESULO08032182
Ricezz hai maggiori info a riguardo... che tipo d'intervento pensi gli stiano facendo...
se ti puo' essere utile la bts di Desulo è attualmente 2G900gms/edge 3G900 e 3G2100 con 1° e 2° layer...
che stiano per mettere il 3° layer?
Ecco, queste sono foto della bts wind di Desulo la NU066, scattate il 27 settembre 2015
O terzo layer oppure se non ha i 43mbit sarà un potenziamento di questo tipo. Impossibile che sia LTE, almeno credo.....
Sì:
PROVINCIADATA INIZIO ATTIVITALOCALITACAPSITI IMPATTATINEW ORA INIZIONEW DURATA DISSERVIZIO
AN8 ott 15 00:01:00ANCONA60131181
AN5 ott 15 09:00:00CAMERATA PICENA600201ND1
AN6 ott 15 09:30:00FABRIANO60044182
AP6 ott 15 08:00:00MONTEFIORE DELL'ASO63010181
AP6 ott 15 09:00:00MONTEFIORE DELL'ASO630101ND3
AQ7 ott 15 09:00:00BALSORANO670521ND4
AQ5 ott 15 09:00:00TAGLIACOZZO670691ND3
AR9 ott 15 08:00:00AREZZO52100184
AR7 ott 15 08:30:00CASTIGLION FIBOCCHI52029184
AR7 ott 15 08:30:00POPPI52014184
CA8 ott 15 23:30:00BALLAO09040282
CA8 ott 15 23:30:00BALLAO09040281
CA5 ott 15 08:00:00CASTIADASND185
CA7 ott 15 08:30:00QUARTU SANT'ELENAND185
CA6 ott 15 08:30:00QUARTU SANT'ELENAND185
CA6 ott 15 00:01:00QUARTUCCIU09044181
CA5 ott 15 08:00:00SAN VITO09040185
CA8 ott 15 08:30:00SELARGIUS09047184
CA8 ott 15 23:30:00VILLASALTO09040281
CA8 ott 15 23:30:00VILLASALTO09040282
CB8 ott 15 23:30:00MORRONE DEL SANNIO86040181
CB8 ott 15 23:30:00MORRONE DEL SANNIO86040182
CH8 ott 15 11:00:00BOMBA66042183
CI5 ott 15 10:00:00DOMUSNOVASND182
CI5 ott 15 11:00:00GONNESA09010181
CI7 ott 15 08:30:00SANT'ANNA ARRESI09010185
CI6 ott 15 08:30:00SANT'ANNA ARRESI09010185
CI5 ott 15 08:30:00SANT'ANNA ARRESI09010185
FI6 ott 15 10:00:00BORGO SAN LORENZOND185
FI8 ott 15 00:01:00FIRENZE50134181
FI5 ott 15 23:00:00FIRENZE501271ND4
FI6 ott 15 08:00:00FIRENZE50134181
FI5 ott 15 23:00:00FIRENZE50127181
FM8 ott 15 09:00:00ALTIDONA630161ND3
FM7 ott 15 05:00:00FERMO63023182
FM7 ott 15 05:00:00GROTTAZZOLINA63024182
FM7 ott 15 05:00:00MONTAPPONE63020282
FM7 ott 15 05:00:00MONTEGIORGIO63020282
FM7 ott 15 09:15:00SANTA VITTORIA IN MATENANO610281ND3
FM7 ott 15 05:00:00SANT'ELPIDIO A MAREND282
FM7 ott 15 05:00:00SERVIGLIANO63029182
FR5 ott 15 08:00:00ALATRIND184
FR5 ott 15 08:00:00CASSINOND181
LI8 ott 15 14:00:00LIVORNO57128182
LT7 ott 15 08:00:00CISTERNA DI LATINA04012184
LT7 ott 15 08:00:00SONNINO04010184
LU5 ott 15 08:30:00CAPANNORI55012184
LU6 ott 15 09:00:00SERAVEZZA55047183
LU6 ott 15 08:30:00VIAREGGIO55049183
LU8 ott 15 08:30:00VIAREGGIO55049183
LU9 ott 15 08:30:00VIAREGGIO55049183
LU7 ott 15 08:30:00VIAREGGIO55049183
MC7 ott 15 05:00:00CIVITANOVA MARCHEND282
MC7 ott 15 05:00:00CIVITANOVA MARCHE62012182
MC7 ott 15 05:00:00CORRIDONIA62014182
MC6 ott 15 09:00:00ESANATOGLIA620241ND3
MC7 ott 15 05:00:00MOGLIANO62010282
MC7 ott 15 05:00:00MONTE SAN GIUSTO62015182
MC7 ott 15 05:00:00MORROVALLE62010282
MC6 ott 15 09:00:00PIEVE TORINA620361ND3
MC9 ott 15 09:00:00SAN SEVERINO MARCHE620271ND2
MC7 ott 15 05:00:00SANT'ANGELO IN PONTANO62020182
MS6 ott 15 14:00:00MASSAND182
NU6 ott 15 10:00:00MACOMER08015182
OT5 ott 15 14:00:00ARZACHENA07021183
PI5 ott 15 08:30:00PISA56100183
PI5 ott 15 14:00:00SAN GIULIANO TERME56017182
RI6 ott 15 23:30:00FARA IN SABINAND12231
RI6 ott 15 23:30:00FARA IN SABINAND1201
RI6 ott 15 08:00:00RIETIND184
RI6 ott 15 08:00:00RIETI02100184
RM6 ott 15 23:30:00CAPENA00060301
RM6 ott 15 23:30:00CAPENAND1201
RM6 ott 15 23:30:00CAPENA000603231
RM6 ott 15 23:30:00CAPENAND12231
RM6 ott 15 23:30:00CASTELNUOVO DI PORTOND12231
RM6 ott 15 23:30:00CASTELNUOVO DI PORTO000603231
RM6 ott 15 23:30:00CASTELNUOVO DI PORTO00060301
RM6 ott 15 23:30:00CASTELNUOVO DI PORTOND1201
RM6 ott 15 23:30:00FIANO ROMANO000652231
RM6 ott 15 23:30:00FIANO ROMANO00065201
RM6 ott 15 23:30:00FIUMICINO000547231
RM6 ott 15 23:30:00FIUMICINOND12231
RM6 ott 15 23:30:00FIUMICINOND1201
RM6 ott 15 23:30:00FIUMICINO00054701
RM6 ott 15 23:30:00MORLUPO00067101
RM6 ott 15 23:30:00MORLUPO000671231
RM6 ott 15 23:30:00NEROLA000171231
RM6 ott 15 23:30:00NEROLA00017101
RM7 ott 15 08:00:00POMEZIA00040184
RM5 ott 15 08:00:00POMEZIA00040581
RM8 ott 15 08:00:00ROMA00138183
RM5 ott 15 23:30:00ROMA00100101
RM7 ott 15 22:00:00ROMA00155182
RM6 ott 15 23:30:00ROMA00119101
RM6 ott 15 23:30:00ROMA00124701
RM6 ott 15 23:30:00ROMA00125401
RM6 ott 15 23:30:00ROMA001254231
RM7 ott 15 23:30:00ROMA001361231
RM7 ott 15 23:30:00ROMA001532231
RM7 ott 15 23:30:00ROMA00168301
RM6 ott 15 23:30:00ROMA00122301
RM6 ott 15 23:30:00ROMA001631231
RM7 ott 15 23:30:00ROMAND301
RM7 ott 15 23:30:00ROMA0010026231
RM7 ott 15 23:30:00ROMA001864231
RM7 ott 15 23:30:00ROMA001924231
RM6 ott 15 23:30:00ROMA00121201
RM7 ott 15 23:30:00ROMAND3231
RM7 ott 15 23:30:00ROMA001002601
RM7 ott 15 23:30:00ROMA001492231
RM7 ott 15 23:30:00ROMA00153201
RM7 ott 15 23:30:00ROMA00163201
RM7 ott 15 23:30:00ROMA00165201
RM7 ott 15 23:30:00ROMA001652231
RM7 ott 15 23:30:00ROMA001873231
RM8 ott 15 08:00:00ROMA00100184
RM8 ott 15 22:00:00ROMA00155182
RM6 ott 15 23:30:00ROMAND1201
RM6 ott 15 23:30:00ROMA001191231
RM6 ott 15 23:30:00ROMA001212231
RM6 ott 15 23:30:00ROMA001223231
RM6 ott 15 23:30:00ROMA00126201
RM6 ott 15 23:30:00ROMA00127101
RM7 ott 15 23:30:00ROMA00151101
RM7 ott 15 23:30:00ROMA001632231
RM5 ott 15 08:00:00ROMAND182
RM8 ott 15 08:00:00ROMA00100182
RM6 ott 15 23:30:00ROMAND12231
RM6 ott 15 23:30:00ROMA001001101
RM7 ott 15 23:30:00ROMA00186401
RM7 ott 15 23:30:00ROMA00187301
RM7 ott 15 23:30:00ROMA00192401
RM7 ott 15 23:30:00ROMA00193201
RM7 ott 15 23:30:00ROMA001932231
RM6 ott 15 23:30:00ROMA001262231
RM6 ott 15 23:30:00ROMA001481231
RM7 ott 15 23:30:00ROMA00136101
RM7 ott 15 23:30:00ROMA001484231
RM7 ott 15 23:30:00ROMA001511231
RM8 ott 15 08:00:00ROMAND184
RM5 ott 15 23:30:00ROMA001001231
RM6 ott 15 23:30:00ROMA001247231
RM6 ott 15 23:30:00ROMA00148101
RM6 ott 15 23:30:00ROMA00163101
RM7 ott 15 23:30:00ROMA00148401
RM7 ott 15 23:30:00ROMA00149201
RM7 ott 15 23:30:00ROMA00167401
RM7 ott 15 23:30:00ROMA001683231
RM6 ott 15 08:00:00ROMA00100182
RM6 ott 15 23:30:00ROMA0010011231
RM6 ott 15 23:30:00ROMA001271231
RM7 ott 15 23:30:00ROMA001674231
SI7 ott 15 08:30:00COLLE DI VAL D'ELSA53034184
SI6 ott 15 08:30:00MONTERIGGIONI53035184
SI6 ott 15 08:30:00POGGIBONSI53036184
TE6 ott 15 10:00:00TERAMO64100182
VT5 ott 15 08:00:00VITERBO01100184
AP5 ott 15 09:00:00SAN BENEDETTO DEL TRONTOND182
CA7 ott 15 08:00:00DECIMOMANNU09033288
CB8 ott 15 09:30:00ROTELLO86040185
CI7 ott 15 08:00:00SAN GIOVANNI SUERGIU09010188
FM7 ott 15 09:00:00MONTEGRANARO63014181
FM7 ott 15 09:00:00SERVIGLIANO63029188
LU8 ott 15 09:30:00VIAREGGIO55049182
MC6 ott 15 09:00:00VISSO62039187
PG6 ott 15 11:00:00GUBBIO06024182
PG8 ott 15 00:01:00PERUGIA06100181
PG6 ott 15 11:00:00UMBERTIDE06019182
RM5 ott 15 08:00:00ROMA00118184
RM5 ott 15 08:00:00ROMA00174188
RM6 ott 15 09:30:00ROMA00138183
RM7 ott 15 08:00:00ROMA00174188
RM5 ott 15 13:00:00ROMA00100182
RM5 ott 15 09:30:00ROMA00155185
RM5 ott 15 08:00:00ROMA00128185
SS8 ott 15 00:01:00SASSARI07100181
TE7 ott 15 10:00:00TORTORETO64018182
Riccez ha detto:
Finalmente altri interventi vicino casa mia,a Fiano Romano e Fara in Sabina speriamo sia qualche intervento per il 4G dato che i 900 a Fiano (solo a uno o due impianti) e Fara in Sabina sono già attivi.
Grazie per questi aggiornamenti!!
Grazie Riccez, chi sa che stanno facendo qui a Fiumicino RM vicino al palazzo del comune su un palazzo hanno messo 3 pannelli piccoli che hanno 4 cavi più un link radio, spero che si wind la tim non e ne sono sicuro lo provato sti giorni per me e wind o vodafone. a dimenticavo dei 4 cavi solo due sono collegati ai pannelli
Controllato poco fa, U900 attivato, mi rimane da vedere se hanno eseguito interventi sulla bts date le 4 ore di disservizio.
Predisposizioni LTE?
Grazie Riccez.. chiedi a Wind se ti ridanno gli interventi suddivisi per tipo (LTE, 3G 900.. :p )
