Aggiornamento firmware Nokia 5800: 21.0.025
Come da titolo...
Ho appena aggiornato il mio 5800 via OTA e devo dire che i miglioramenti sono ben visibili, maggiore velocità generale ( soprattutto il cambio di visualizzazione da verticale ad orizzontale) e altre cosucce aggiunte.
Ecco il changelog:
  • Lock code does not work after FOTA update
  • Logs: Info cannot be seen in missed calls if name includes special characters
  • The envelope icon doesn’t open after reading the sms
  • Autolock requested via MfE but not activated
  • MPX harvester server crach with DRM files
  • Oper. menu application icon missing after NSU update
  • CDP Displays: CDP Clock and Data Have To Be Transmitted 2 Frames Before Sleep Out (SLPOUT 11h) Command
  • “Program closed: Idle” after Restoring factory settings
  • Video telephone: Phone reboots after tap call button several times when answer an incoming video call
  • Music Player crashes when user tries to refresh Real audio into Music library
  • Dialer: The cursor is not displayed in dialer panel
  • Audio disappears after playing music long time with BT
  • Music player the album art in Now Playing view is downscaled
  • Access point password is not provisionable
  • Voice commands application crashes after language change
  • Synchronization cannot be done using PC Suite Sync application
  • FL3.0: Inline Text editing from browser plugin is not successful
  • Browser does not show some MIME-types of type image correctly
  • Browser: Not possible to move the cursor when typing in a <textarea> field
  • Browser: Page scroll wobbles if user scrolls with flash while page is in scroll motion
  • Browser: Page does not scroll if drag is started from the edge of flash window
  • Browser: Page scroll does not work after stopping going to new page opened via flash banner
  • Bluetooth causing extra current consumption when activated
  • Predictive search not working properly in country selection
  • Music Player application crashes if album art is selected to be changed
  • Duplicate contacts after restore
  • Music Player: White screen displayed if change orientation between landscape and portable mode
  • MO/MT calls will not work when restoring backup from old phone to more recent version
NEW FEATURES AND APPLICATIONS
  • Notification Lights according to Nokia Design specification
  • Touch usability improvements:
  • Finger touch support for Special Character Table
  • Size of arrows (tab pane & navi pane) in touch UI
  • Arrows in forms, date & time selection, touch UI
  • Profile, date area in touch UI
  • Calendar Finger usability: change single row list items in day view wider
